Pixel Art Topic is solved
zhichunp
Pixel Art
Post by zhichunp »
Greetings, Its my first time posting so hopefully I'm doing this correctly...
I've been trying to make pixel art with the mechanical pencil tool on a 240 x 135 canvas, and during export I upscale the canvas by 8 so it's in 1080. However, this turns everything blurry. Does anyone know how to get around this? I've also tried using the grid but its surprisingly ineffective, the whole thing only looks pixelated but in reality isn't accurate. Thanks a lot!
ematecki
Re: Pixel Art
Post by ematecki »
Cut the whole project with the "cut brush" tool.
Then edit the brush, set the size to whatever you want, set "AAliasing" to "None".
Then in the export panel, at the very top, choose to export the "Custom Brush".
Re: Pixel Art
Holly molly, I did not think about this :lol:
This is so smart, I feel now terribly dumb :mrgreen:
Norman, you now have your solution :)
mox
Re: Pixel Art
Post by mox »
I use the Edit Brush way too :)
If you want to draw straight to a 1920x1080 project, things are a bit tricky:
- add a 8x8 grid (for a 240x135 picture in 1:1),
- use a square/brush of 8x8 (to fit the size of the grid),
- set the color mode (of the brush): from 'original stamp' to 'alpha stamp' to be able to change your colors on the fly,
- draw with 'free hand dotted line' not "free hand stroke", it's the only way to stay within the lines!
Jerome Lorin
Moxica (playground)
(Win11/TVP 12.0.3 pro)
zhichunp
Re: Pixel Art
Post by zhichunp »
Thank you friends! That was very helpful. you people deserve a Nobel prize for the smart use of cut tool...
However I think mox's second method might be more effective when animating a longer scene? Since the cut brush would need to cut and export each frames individually, or am I doing this wrong again...?
Re: Pixel Art
No, the cutbrush works over any range of frames (which you have to select first).
zhichunp
Re: Pixel Art
Post by zhichunp »
Ok all my problems are solved now... Thank you everyone :D
