I have a silly problem, it occurred somehow in the process of switching to fullscreen mode and back.
Is there a way to move tvpaint around so I can position it so that all of the interface is visible again?
Mac menu covering TVpaint Topic is solved
- Screen Shot 2017-12-13 at 10.43.22.png (13.56 KiB) Viewed 18500 times
Re: Mac menu covering TVpaint
The only way I've managed to fix this, is by changing the resolution of the screen and drag tvp window to a different location.
Hi Bridagiers,
To fix this, click with the left mouse button on one of the corner of the window and maintain it (like if you want to resize it) then, press the button Alt and don't release it.
Then drag your mouse. The window should normally schrink and the title bar will appear so you will be able to move it.
Best,
Best,
Thank you Thierry and kariP!
I'm all good now!
I'm all good now!
I didn't know you could do that, Thanks Thierry!
- Animationriver
HELLO. I can not do it.Thierry wrote: ↑13 Dec 2017, 10:24 Hi Bridagiers,
Best,
can make a small video from the screen?
