Anim Brush editing
Olpol
Anim Brush editing
Post by Olpol »
Hi,
I was trying to search for a post on editing Anim brushes. I'd like to edit an anim brush that has already been created. I'd like to do more than just flip, scale etc. Is there a way to edit the whole timeline of an custom anim brush, change the drawings, or delete or add frames? Or will it need to be recreated from scratch?
thanks in advance,
O
Re: Anim Brush editing
That's why I try and keep a separate project for each of my brushes.
edit animbrush.mp4
(13.89 MiB) Downloaded 1192 times
This is how I do usually :)
Olpol
Post by Olpol »
I see thats helpful to know.
So the document area of the project for the brush will hopefully stay the same for consistency, you then go back, change the frames and save the project and overwrite the same brush? Or do create a new custom brush within the project and export that?
Each time you create a brush it's a new one. It depends on you if you want to save it in a custom panel, and under which name.
Olpol
Post by Olpol »
Ok great, many thanks for the help!
