I used to use Vincenwoo 66 oils custom panel in TVP 8. I'd love to use them again but I can't get it to install on TVP 11 pro. Can you give me any guidance?
Charles Bandla
Installing pre-tvpx custom panels in TVP 11 Pro Topic is solved
Re: Installing pre-tvpx custom panels in TVP 11 Pro
Nevermind, I remembered that custom panels could be install directly in to the application. I copied the bin and data files into the plugin directory (Mac) and they were available after restarting TVP.
Charles Bandla
Charles Bandla
Can you export them as a tvpx now you have them activated? Is it possible to share? I'd love to see some good oils.
http://www.daninski.com
