Hi,
The Flips panel is really fully of setting to make it the way you want. But often with these very flexible settings it can be hard to set what you want.
I would like to have when pressing the assigned key
It start to play on the instance before the current instance and play the 2 next ones on that flip.
How would that setting be?
/ Mattias
Flips - panel setting
- hellofilms
Windows 11 - TVpaint Pro 11.7.4 & 12.0.2 .- Wacom cintique 24 Pro
Re: Flips - panel setting
Why don't you select the frames you want to play before hitting space bar to play the selection ?
- hellofilms
Hi,
Yes that would work too.
but as more looking for more entuitive way to do it.
Just hitting a key . like you flip on papers before. I remember I found the setting before this new flip panel was presented.
I have to dig more into the settings.
/ Mattias
/ Mattias
From memory, you can create a Basic flip and use "custom" limits, to be -N images before to +N after.
- hellofilms
I got it right in the end.
Thanks.
/ Mattias
Thanks.
/ Mattias
