Light table stuck. Topic is solved
Henk Beumers
Light table stuck.
Post by Henk Beumers »
Hi all.
Some how I managed to get the light table window fixed in an odd position. After I minimized the window by means of the symbols in the top right corner, it will not maximize into the full maximized size it was before. It now opens like in the attachment. There is no way I can open it more. It's not possible now to adjust the transparentcy of the frames.
Everything else I can adjust like the number of frames, the color ect.
Thanks
Henk Beumers.
Henk Beumers
TVP 10.05.7 pro 64 bits W7 pro 64 bits. Intel i5 2.67. Mem 16gig.
Re: Light table stuck.
Henk Beumers wrote: 01 Feb 2018, 10:37 Hi all.
Thanks
Henk Beumers.
See: https://www.tvpaint.com/forum/viewtopic ... 65#p104114
This is an old bug in TVPaint 10 , now fixed in TVPaint 11. Unfortunately in TVPaint 10 the only solution is resetting your whole interface .
It means you'll lose shortcuts and custom panels. You can export all of your shortcuts and custom panels first so you can reload them later .
Henk Beumers
Hi Nethery.
Thanks. First time this happened to my and I use TVP10 since it's out.
I first thought it's me not remembering how to adjust that window. It's always there in a cluster of windows and I hardly ever touch it.
Oké. I know what to do. Thanks again.
Henk Beumers.
Henk Beumers
Henk Beumers
Hi Nethery./all
Today when I opened Tvpaint the lighttable window was as always showing it's sliders. It's likely part of the same issue.
It comes and it goes. It's alive.
Regards Henk Beumers.
ANIWHY
Henk Beumers
