not correctly import the video Topic is solved
Animationriver
Post by Animationriver »
Hello everybody. 11 version of the program ... It does not correctly import the video. Skips frames, unauthorized pauses appear in the video ... Does anyone have such a problem? And how to fight it. (Windows 7 x64 my friend) & i have this problem sometimes... :D
Re: not correctly import the video
Maybe you're using a video codec TVPaint interprets in a weird way. Which codec do you use and have you tried another?
Animationriver
schwarzgrau wrote: 07 Mar 2018, 11:55 Maybe you're using a video codec TVPaint interprets in a weird way. Which codec do you use and have you tried another?
quick time in my system MAC OS Sierra
My friend Win 7 ( i do not know codec)
Hmmm, it's hard to tell, without knowing the codec.
Animationriver wrote: 07 Mar 2018, 14:30
quicktime in my system MAC OS Sierra
The compression codec can be found in Quicktime Player > Windows > Show Movie Inspector.
For example, this shows that the compression codec is H.264 -
Or on Windows in VLC Player , it is Windows > Media Information > Codec Details
Screen Shot 2018-03-07 at 11.01.23 AM.jpg (72.82 KiB) Viewed 15159 times
Animationriver
Thanks!
If the FPS file and fps in the project match - this means that distortions are excluded. Yes? :D
Animationriver wrote: 07 Mar 2018, 17:28 Thanks!
Yes, the Project FPS should match the video file FPS , so a video file at 24 FPS should be imported to a TVP Project set at 24 FPS.
