Hi,
I would like to export all my layers separately automatically of a same clip to avi files with an alpha for each. I think there is no solution exept export all the layers one by one.
Thanks for answering
J
EXPORT LAYERS SEPARATELY
Re: EXPORT LAYERS SEPARATELY
Hi, I haven't tried. But maybe this link will help
viewtopic.php?f=11&t=6978&hilit=export+After+Effects
you can export all the layers separately in one go, but as a psd image sequence. You can turn them into avi's in AE or import them into a video editor.
It's in export> clip: layers structure. Select sequence and psd.
http://www.daninski.com
As mentioned , Export > Clip: Layers Structure > PSD
OR
Export > Clip: Layers Structures > JSON .
https://www.youtube.com/watch?v=HtQIii_AXR0
Basically the same as the Mads Juul custom panel referenced in the post above by Tylos: viewtopic.php?f=11&t=6978
It's intended to export all layers intact in a format that can be imported into After Effects . But what you end up with is a folder with all layers
as PNG image sequences (with transparency) , which can be imported to AE (with the json file and the custom script for importing into AE) .
You could also open each PNG image sequence in Quicktime Pro (if you have QT Pro 7 on a Mac) and then choose Export > Movie to AVI in the export menu of
QT Pro .
But this seems to me just as slow as exporting each layer one at a time as an AVI from TVPaint ... so I don't know if it really solves your issue.
OR
QT Pro .
