Hi,
I'm having some annoying issues with using the pen in TVPaint.
When I try to do a quick circle a jagged edge will appear as in the attached. Also when I try to make a quick curve from corner to corner it attempts to complete the end of the line and then jumps back.
I'm using an Intuos 4 and also getting the same results using the mouse. I've also downloaded the laters driver. I don't have these issues in Photoshop.
Do you have any advice?
Many thanks
Ryan
Trouble with brush pen
- pen examples00049.jpg (44.68 KiB) Viewed 12690 times
Re: Trouble with brush pen
What is your Operating System?
Have you removed every trace of previous tablet drivers before installing new ones?
However, if you are having the same issue with the mouse, make sure first that you don't have any guideline activated.
Regards,
Mélanie
Regards,
Mélanie
Melanie • Animator
Hi Melanie,
Mac OS Sierra 10.12.6
I don't think I would have removed any previous tablet driver versions.
No guidelines activated.
Thanks
Ryan
Thanks
Ryan
Hi Melanie,
Any more thoughts on this? I've uploaded a video of the line when it jolts at the tip.
Thanks
Ryan
Mac OS 10.12.6, 64 bit, Intuos 4, TVP 11 Pro
Thanks
Ryan
- tvpaint-line.mov
- (11.65 MiB) Downloaded 801 times
is it this issue?:
viewtopic.php?f=10&t=11409#p109264
that was resolved here:
https://www.tvpaint.com/forum/viewtopic ... 60#p108060
It's similar, drawing circles and getting a jagged edge in places, not necessarily at the start. It's a lot smoother on Photoshop. And the other problem is the line jolting back at the end of a stroke.
I've tried turning off the tip double click distance and full screen mode which hasn't made a difference.
