Hi, this is a basic export question
I 'm working on 24 frames/sec and need it to be exported in 30frames h264
i know changing the frame rate in tv paint will mess up my timing
but will bringing into after effects with comp setting as 30frames/sec mess up my timing?
or should i change the comp settings in after effects to 24frames/sec then export it to 30frames/sec?
thank you.
Converting to different frame rates
Re: Converting to different frame rates
If the intended output for the finished product is 30 FPS , then the best way would be to animate with your TVPaint project set for 30 FPS.
But if you're asking: "Can I animate at 24 FPS in TVPaint , then after the animation is finished convert the animation to 30 FPS without messing up the timing ?" , the answer is yes ; it's a process called 3:2 pulldown . 3:2 pulldown converts 24 FPS film speed to 29.97 FPS video .
https://www.extron.com/company/article. ... 32pulldown
