Hi,
I've been working on a few projects with TVP Animation and am having some problems with exporting.
First off, no matter what file format I export to, the Config button does nothing.
How do I export a PSD and keep layers? I've been trying to figure that out but all I end up with is a single layer PSD file.
I'm using TVP 8.1 on an IntelMac with OS X 10.4.9.
Thanks,
Mike Rhdoes
Exporting -- Config button does nothing
- cartoonM!ke
I don't want it all --
Where would I put it?
Mike,
to export properly in PSD format with all your layers, when you are in the export panel, make sure that you are in the "Project Layers" tab.
You'll see that way that the only export format which is offered is PSD and it allows you to export in PSD format with layers.
I agree that it could be integrated to the main export tab "Project Display" though
Also, if you are in the "Project Display" tab with the PSD format selected and then that you click on the Config button, nothing happens because it only allows you to export in PSD with the layers merged. Either the Config button could be disabled or greyed, either the option to export with layers (or not) could be simply implemented in the Config button.
Re: Exporting -- Config button does nothing
"Config" button should work with these following formats :cartoonM!ke wrote:... First off, no matter what file format I export to, the Config button does nothing.
- Quicktime
- AVI
- TGA
- Cineon
- Tiff
- SGI
... at least, it does on PC.
- cartoonM!ke
