Random with a range?
Posted: 28 Apr 2007, 21:08
by djm99001
Is it possible to write a plugin or script that could limit the randomness to within a range? For example, perhaps I have a brush that I want to rotate between -45 and +45 degrees randomly, so that it gives a jitter but keeps its general orientation.
Also, when I am controlling the brush size by pressure, sometimes I don't want the size to go so small--perhaps from 30 to 50 pixels, rather than from 1 to 50 pixels.
And why can't the opacity be controlled by pressure? Is that just the same thing as power?
David
Posted: 29 Apr 2007, 08:49
by Patrice
Hi djm99001,
You can use the function RND(random). This function return a number between 0 and random.
So to have a value:
- between -45 and 45, you can write:
angle = RND(90) - 45
- between 30 and 50:
pixel = RND(20) + 30
All parameters, you can link with your pen, can be controlled by pressure.
