Hi!
So this may be a really silly question -
A festival is requesting file formats of my film in HD1080i and Apple prores 422HQ.
I know that I can export an uncompressed .MOV and normal AVI Internal, but is there a way to export the formats they are requesting? Sorry for such a silly question but never had to really export these formats so just feel a bit lost and internet searches haven't helped much!
(I am working on a Windows, using 64bit TVPaint 11 Pro.)
Thank you!
Exporting in 1080i and Apple prores 422HQ
Re: Exporting in 1080i and Apple prores 422HQ
With the 64bit version the Export formats are .AVI and FFMpeg .MOV . So technically , no , you can't export to Apple ProRes 422HQ directly from the 64 bit version of TVPaint. (Quicktime is not compatible with 64bit and technically , not compatible on Windows at all , since Windows users were all advised to uninstall Quicktime due to security risks because Apple stopped providing security updates for Quicktime on Windows) .
Here's a suggested workaround:
1.) the main security issue for Windows is the Quicktime browser plug-in and downloading Quicktime .MOV files from unknown sources, then playing them with Quicktime Player on your Windows computer . The actual Quicktime codecs are not a security risk if you're using them internally for exporting your own files. So you need a way to keep the Quicktime codecs , but dump the Quicktime player and browser plug-in . Here's how to do that:
https://www.cinecom.net/video-editing-t ... ep-codecs/
2.) Download the 32bit version of TVPaint . You can have both the 32bit version and 64bit version on your computer . Open your project in the 32bit version and go to File menu > Export To > Then choose Quicktime and from the list of available codecs choose Apple ProRes 422HQ .
However, the big issue for you is that I don't know if you can actually get the Apple ProRes 422HQ codec for Windows ? (I'm on a Mac here , I don't have a Windows computer) . Maybe if you install FFMpeg codecs for Windows https://ffmpeg.org/download.html there is an "FFMpeg equivalent" codec to ProRes 422HQ .
On the 64bit version you should try a test export using FFMpeg .MOV - Compressed RGB-RGBA (the third option on the list under FFMpeg .MOV) .
See if that format will be acceptable to the festival.
If not , do you have any friends who have TVPaint running on a Mac ? They could open your project on their Mac in TVPaint 32bit version and export it to ProRes 422HQ for you.
Another suggestion would be to look at a free application called MPEG Streamclip Video Convertor - http://www.squared5.com/svideo/mpeg-streamclip-win.html . It can convert .AVI and .MOV files to various codecs , including Apple ProRes 422HQ. Of course I think it depends on whether you can get the Apple ProRes 422HQ codec installed on your Windows machine , whether or not you'll have access to it in the list of available codecs in MPEG Streamclip.
Thanks for replying!
No friends have it on a mac sadly- first thing I tried (would have saved a lot of trouble!)
So I installed 32 bit (didn't know I could have both- handy to know; thanks!) It didn't give me the option for pro res , I've attached images of what was available.
I think for the festival exports I can do either Apple Pro res or HD 1080i - Since Prores isn't working, I've done as you suggested and exported it as a .Mov through the 64 bit version. But do you have any idea how I can go about saving it as a HD 1080i? Is it just a case of selecting 'upper first' in the field section instead of progressive?
- 1 32bit.JPG (42.25 KiB) Viewed 12858 times
- 2.JPG (51.34 KiB) Viewed 12858 times
- 3.JPG (48.27 KiB) Viewed 12858 times
I would still suggest from the 64bit version you try the third FFMpeg option - "Compressed-RGB/RGBA" , which as I understand it is the FFMpeg equivalent of ProRes .
I would definitely suggest that you NOT use H.264 compression codec as in your screen shot, because H.264 has poor color fidelity , it will make your colors look washed out.
I've never used export to HD 1080i ... I had to look it up ... what I found says:
I don't know which is preferable , 1080i50 or 1080i60.
So two of the choices I see in my 32bit version Quicktime export options are HDV 1080i50 and HDV 1080i60 , I believe the 50 and the 60 referring to what is mentioned above where it says "a temporal resolution of 50 or 60 interlaced fields per second.""The number "1080" refers to the number of horizontal lines on the screen. The "i" is an abbreviation for "interlaced"; this indicates that only the odd lines, then the even lines of each frame (each image called a video field) are drawn alternately, so that only half the number of actual image frames are used to produce video. A related display resolution is 1080p, which also has 1080 lines of resolution; the "p" refers to progressive scan, which indicates that the lines of resolution for each frame are "drawn" in on the screen sequence.
The term assumes a widescreen aspect ratio of 16:9 (a rectangular TV that is wider than it is tall), so the 1080 lines of vertical resolution implies 1920 columns of horizontal resolution, or 1920 pixels × 1080 lines. A 1920 pixels × 1080 lines screen has a total of 2.1 megapixels (2.1 million pixels) and a temporal resolution of 50 or 60 interlaced fields per second."
I sent a Compressed RGB/RGBA to them and will see what they say.
HDV 1080i doesnt actually come up on mine- I get the AVI ettc as standers then is says convert but I have HDTV 1080 (no i ). With quicktime there isnt that option in the compression type.
SO from what I can see- I do AVI , HDTV 1080, upper first to make it interlaced.
I've doen this and the quality matches the Mov so thats good- no glitches either; but the file size is about 14gb? Would that be an issue for playback or should I be exporting it differently?
Sorry for the delay in replying - internet went haywire and I get back too late to call them.
