Tool bar export fail
Amili
Post by Amili »
Hi!
I'm trying to export my brushes from tvpaint 9.5.
(Installing soon top 11 so I want to save my brushes)
But I get a notification: export fail
or nothing at all
or a crash.
Any ideas?
Re: Tool bar export fail
Amili wrote: 29 Jun 2018, 13:04 Hi!
or nothing at all
or a crash.
Any ideas?
Which version of TVPaint 9 ? (if I recall, the last iteration before the jump to 10 was 9.5.21 ... you can check yours by going to Help Menu > About TVPaint Animation to see which version you have) .
Amili
Post by Amili »
Yep, 95.21
and iMac 10.13.5.
Actually now I succeeded with it :D
Let's see if the problem keeps occurring.
But I faced another problem: how to export papers as well. When I open the brush in the new version, my papers are not there of course.
So any way to export papers as well (with the brush or separately)?
I will need to send the brush with correct paper to another animator as well.
(Should I make a new topic out of this..?)
Thanks!
Ami
You just need to copy the papers folder's content in the finder. Go to TVP in the applications folder, choose "Show content", Contents/Resources/papers. I use this to get rid of all textures I don't need, and to put my own ones inside.
Amili
Post by Amili »
Great! Thank you, that's good to know!
Oh, but when I went there I did't find my papers stored in that folder?
Any ideas where they might be..?
My papers, paperi2 etc
Papers folder in Finder
Hm, no idea. There's a TVP folder in user/library/ which stores all your prefs, but no papers there. Have you done a finder search with one of the paper names?
Amili wrote: 29 Jun 2018, 14:00 Yep, 9.5.21
and iMac 10.13.5.
Oh, ok, good to know that you got it working. I was going to say, if yours was lower than 9.5.21 , better to update it first , then try to export your Custom Tool Panels as .tvpx files , which you can then drag-and-drop into TVPaint 11 .
As far as the papers , I would have said the same as Slowtiger above , but if you've got custom papers that are not showing up in the folder , I'm not sure how to find those custom papers.
I've got a certain brush/toolbar which doesn't export as TVPX either in 10 nor 11 (brought it over by copying prefs). Because of this I made it a habit to save a "brush construction" TVP file which contains not only all frames I used but also a screenshot of the brush's settings.
