Add text in the Notes area
melanie
Post by melanie »
Here is a custom panel with two ways of adding text to your Notes area:
Notes Text.tvpx
(152.5 KiB) Downloaded 281 times
notes text.png (2.96 KiB) Viewed 2695 times
The text will be added as pixels and handled as the usual notes.
type your text.png (2.49 KiB) Viewed 2695 times
"Notes 3 lines" will allow you to write 3 lines of text. But 3 lines only.
3 lines.png (3.13 KiB) Viewed 2695 times
If you make a selection of one or several images, your text will fit the selection.
my selection.png (3.41 KiB) Viewed 2695 times
Notes Text.tvpx
(152 KiB) Downloaded 246 times
Melanie • Animator
Re: Add text in the Notes area
This is useful, thank you.
Would it be possible to make the text size adjustable , so it could be smaller text ?
Cardin
Post by Cardin »
D.T. Nethery wrote: 16 Aug 2018, 14:46 Would it be possible to make the text size adjustable , so it could be smaller text ?
This will make it so the text tool is not changed to the parameters specified in the original code. So the settings you had before you activated the function will persist.
Steps to get to the window above are in the spoiler
Spoiler : :
Right Click on the icon[/b]
Hit the drop down menu on line zero and select "Embedded George Script"
You can change the font size here
TVPaint 12.0.0 Pro
Thank you , kind sir !
It is true that in almost all cases "anything is possible in TVPaint" , so thanks for affirming that .
Michaelmocky
Post by Michaelmocky »
That is a cool effect. Wonder if you could tweak it to use other two dimensional shapes other than just text. Might help with that win thingiverse
Really useful, thank you Melanie!
