Hi there. Just had a quick question about resizing multiple layers plus their frames of animation all in one shot with the Transform tool. When I do it, I only get the first instances to Scale and Pan, and everything after that still stays the same. I then tried to go in Layer by Layer to select all instances but when I do that with so many moving parts, I basically hafta eyeball where they moved to. Is there is a way to resize all of the layers together while maintaining their position?
Any help appreciated! Thanks!
Edit: Nevermind! Figured it out. Have to click through each layer and hit enter twice and it did all the panning and stuff for you automatically. I was reinputting the Panning number for each layer, hence the eyeballing part.
