The exporter (or importer to After Effects, it is difficult to know for sure) creates image files which are interpreted as nontransparent in After Effects if the image in TVP is the empty frame. I managed to detect images which cause problems and had them interpreted manually as transparent images. This is far from the ideal workflow. It is either with the TVP exporter or the import script. The export and the import script ship with the official build of TVP, I consider this a bug and I would like to be addressed in the development. I was using this settings: TIFF (non-compressed), RGBA, PreMult. the background unticked.
Best regards,
problem with the transparency in the json export/import - BUG report Topic is solved
TV Paint 11.5.3 Windows 10
Re: problem with the transparency in the json export/import - BUG report
Hi.
Indeed this was a bug, the import-json script lacked some instructions in order to interpret the alpha channel correctly on premultiplied footage.
Thanks.
Thanks.
Clement Berthaud, Software Developer, TVPaint Team
Thanks, this was also stressing me out, though it's now August 2020!
Reinstalling the latest JSON script to After Effects sorted it, cheers.
TVPaint 11.010 Pro Mac-64 * MacBook Pro 2019 * OSX 10.15 * AMD Radeon Pro 5500M 8 GB * Wacom intuos 5
