Can you assign a specific size eraser to a stylus button? Topic is solved
BruceM
Post by BruceM »
I've been reading through past posts regarding stylus settings for the eraser function, and I'm still confused as how best to set this up for my use.
I have right click set to my lower stylus button and would like to keep that. I would like to set up the upper stylus button as the erase button.
My question: How do I assign a particular size of eraser to that upper button? Or can you only assign a general "erase" function that you then have to set the size to each time you use it?
melanie
Re: Can you assign a specific size eraser to a stylus button?
Post by melanie »
Hello Bruce,
Turn your stylus to use your upper button to erase. If you want to change the size of the eraser, keep using the upper button to change the size parameter.
Every time you will erase, it will keep the changes you made.
Melanie • Animator
BruceM
Post by BruceM »
Got it.
Thanks Melanie!
