Ruler Tool
deruji
Ruler Tool
Post by deruji »
something I've been missing for a while and have not seen in any program is a decent ruler with subdivisions for measuring. This is something I have frequently wanted when making perspective drawings for backgrounds.
I was thinking of displaying a line with subdivisions that can be set by the user. The ruler would then display these as equally proportionite units. The example image has the ruler in various lengths set to display 5 equal units
Furthermore the ruler has three handles to allow rotation at either end and the middle.
Note: added clarification.
The traditional 2D animator working with local and international artists.
You can help support my work to make traditional animation, here.
Re: Ruler Tool
deruji
Re: Ruler Tool
Post by deruji »
Regrettably it does not feature the desired functionallty.
TheQuestionMark
Re: Ruler Tool
Post by TheQuestionMark »
deruji wrote: 05 Apr 2019, 13:23 Hello,
I recommend using Lazy Nezumi Pro for ruler in the meantime. You can adjust the scale of it. It can rotate too.
It can also do ellipses you suggested on your other thread.
NathanOtano
Re: Ruler Tool
Post by NathanOtano »
Can't you do a set of custom brushs? And then use the shortcuts to transform brushs to fit it in the right place? :)
