tv_connexionsettings Command Crashes TVPaint
TheQuestionMark
Post by TheQuestionMark »
So, I'm setting up several brushes that requires alot different fade settings. When I try to enter the script command " tv_connexionsettings f 1234 " It crashes. Did I type the command correctly? I only just wanted to fade only. It's strange that connection is spelled incorrectly in the command, but that's what TVPaintWiki spells. Is it a typo on the command?
http://wiki.tvpaint.com/index.php?title ... onSettings
TheQuestionMark
Re: tv_connexionsettings Command Crashes TVPaint
I just type " tv_connexionsettings fade 477 " and it works. But I think I found a bug. The Fade that display the amount doesn't refresh when when activate the Fade Script. But the Fade Setting does change though. Is this solved or not?
