What are the George Scripts to Change Hue,Saturation,and Luminosity in Certain Increments? Topic is solved
Are there George Scripts to change certain amount Hue,Saturation,and Luminosity in Amount Certain Increments? Like by 5,2,10, or by 20 each time you press a key? Please Help. I wish there was script/program log so you can have easier time to write scripts. I see it the in Add Actions to increase to decrease but it's only one at a time I want it in amounts.
- Hironori Takagi
Re: What are the George Scripts to Change Hue,Saturation,and Luminosity in Certain Increments?
I think that I will make more than one based on the following.
I think that it is not efficient because it will use many hotkeys depending on the case.
// H+5 command
tv_getapen "hsl"
PARSE result index iH iS iL
iH = iH + 5 // change each param
IF iH >= 360 // iS,iL change 255
iH = iH -360 // iS,iL change 255
END
tv_setapen "hsl" iH iS iL
// H+5 command
tv_getapen "hsl"
END
Hironori Takagi wrote: ↑25 Jun 2019, 09:22 I think that I will make more than one based on the following.
// H+5 command
tv_getapen "hsl"
END
Wow! How did you learn that? I don't see that anywhere in TVPaint Wiki.
I have Macro Keyboard so I still have plenty of keys left.
Hmmmm for Hue it seems it doesn't rotate clockwise "fully" when you set it to negative interger.Hironori Takagi wrote: ↑25 Jun 2019, 09:22 I think that I will make more than one based on the following.
// H+5 command
tv_getapen "hsl"
END
tv_getapen "hsl"
iH = iH -15 // change each param
END
- Hironori Takagi
Excuse me, please add the following.
IF iH < 0
iH = iH + 360 // iS,iL change 255
END
See the post below for the George command.
I learned here the command I didn't even know.
[Documentation for all george commands]
viewtopic.php?f=34&t=12087
IF iH < 0
END
