11.0.9 dropping frames
daninski
Post by daninski »
Just moved from 11.0.8 pro edition to the 11.0.9 version. I'm using Mojave on a 2013 iMac with 16gig of memory.
Problem I'm experiencing is that since the update (with restarts after) the timeline playback is stuttering and dropping frames. It wasn't doing that at all in 11.0.8, and as you can imagine it makes fine tuning the timing in my animation extremely difficult. Like I said, this wasn't a problem before the update. Have you any ideas about how I can improve the situation?
http://www.daninski.com
daninski
Re: 11.0.9 dropping frames
Post by daninski »
I downgraded to 11.0.8 to double check and the problem isn't there in that version. It also opens the files I'm using much more quickly.
I'd avoid upgrading until this issue is fixed as it seriously impedes being able to animate if you can't play back your work consistently.
Update on this: the issue seems to be happening only on Macs. We have identified the problem and working on a fix.
On holidays until May 5th
JeremyN
Post by JeremyN »
Hi,
I have fixed the issue (it should be available to download soon), it only happens on 64bits version by the way.
Daninski, just to be sure we are talking about the same issue, can you do a little test please ?
Open one of your project in TVPaint 11.0.9 and launch the playback. Then, do not touch your mouse or stylus, don't event do a single move with them (I know, it's strange to ask this).
Is the playback dropping frames ?
Now, if you move your mouse or stylus, you should see a big drop in frames during playback. Is it the case ?
On my side, the playback became extremely laggy when I moved the mouse but was smooth if I didn't.
Mac Developer
daninski
Post by daninski »
Hi, I'll have to try this in the evening as I have a couple of jobs going on at once today. I'll update you as soon as I've checked it.
daninski
Post by daninski »
I haven't had time yet to install and try the new version again. Time is tight tight tight!
Hironori Takagi
Post by Hironori Takagi »
I downloaded and checked 11.0-3 yesterday.
We have confirmed the phenomenon that the right-click menu sometimes appears slowly.
Do you know why?
Animationriver
Post by Animationriver »
Hironori Takagi wrote: 20 Sep 2019, 09:36 I downloaded and checked 11.0-3 yesterday.
Do you know why?
There is such a problem on my Mac configuration. :roll:
skeh
Post by skeh »
i also have a same issue laggy on mojave. :cry:
my fat macpro doesn't slow yet
i'm looking forward to update it asap. :D
m1 air
with cintiq pro 27, movink
tvpaint pro 11 on mac
