Using the panning on multiple instances Topic is solved
martimiz
Post by martimiz »
Hi all,
I know I can use the panning tool on multiple instances by selecting a range of frames. But this action always creates new images for every Exposure cell, and there seems to be no setting to prevent that.
So I found (on these forums) that using Image -> Exposure ->Recompute Exposure will then the remove these extra images again. But that feels like such a detour...
Is this really the correct way to proceed or did I miss some setting? And if it is, do I run the risk of losing images when applying this to a large range of frames that I can't easily oversee?
Thanks, Martine
TVPaint 11.5.3 Pro 64 - Mac OSX 12.4 Monterey
iMac 21-5 inch 2017, 3.6 Ghz Intel Core i7, 16 GB RAM
Wacom Cintiq 24 Pro touch, driver version 6.3.46-1
Re: Using the panning on multiple instances
A GEORGE script could be written to do what you want, especially using the tv_Panning command.
sven
You can use FX > Motion > KeyFramer for this and check "Heads only".
Turn off Auto-Break Instance before selecting the range of frames you want to move with the panning tool.
Turn Off Auto-Break Instance.jpg (63.41 KiB) Viewed 20668 times
martimiz
Post by martimiz »
Many thanks for your solutions, guys!
I'm a bit of a beginner, and I haven't mastered George yet, sorry... Both other solutions definitely do the trick. Turning off auto-break (temporarily) seems to be the simplest for now. But it made me look into FX which is also good!
Nice to see that even a simple problem like this can be looked at from so many different angles! :)
Martine
martimiz wrote: 11 Nov 2019, 12:33 Nice to see that even a simple problem like this can be looked at from so many different angles! :)
You'll find this typical for tvpaint. There are usually many ways that lead to Rome.
