Best breast pumps to buy for millennial moms
2dbert
Re: Keyboard Shortcut
Post by 2dbert »
I'm on mac where the right click keyboard shortcut is to hold down ctrl, whereas on windows it's hold down shift and press F10 or something of the sort- too long ago to be sure of that, sorry. I'm pretty sure though that your Wacom pen's buttons can have a right click function assigned to it and I'm surprised that it isn't already by default. Or maybe I don't understand properly, but in any case I recommend to list the details of your setup: software version, Wacom model, operating system and version and so forth when asking for advice
Yiynova MSP19U
TvPaint Animation 11.0.6 Pro
Soom
Post by Soom »
tartarus wrote: 28 Dec 2019, 08:09 Hi,
I found this shortcut item "Right Mouse Button" and tried to use it, but it didn't anything. What this shortcut does and how to use it?
I am using wacom pentablet and can't use Right Mouse Button, so If I can use it with Keyboard, It' s really useful.
Thanks.
Where did you find it - in TVPaint Keyboard settings, or in Wacom settings?
In TVPaint the right click is used for some very specific internal functionality and should not be changed! It is used for zooming (by pressing ALT and Right Click) or for rotating table (press ALT+CTRL+Right Click). And when used with a brush, it uses the same brush as eraser. But I actually think, that if you do modify it, this shortcut will only work with an actual mouse, not with Wacom pen (and it shouldn't!)
