I'm playing around with the idear to a George script where I automaticall ytry to fill an area of all my instances in an animation layer, but I dont know if this is possible.
I just go through the different stages of the script:
* get x,y coordinate for Fill witn Param dot.
* make a fill with tv_fill
* now I would go to the next onstance on the layer but I dont know if this is possible.
I can advance one frame with tv_image = tv_getimage + 1. but can I detect
if the frame is an exposure or image?
* then i would make a new fill but first I would diside if the animation had moved so much that i would fill outside the first area. I could do this by making a selecting first and see if the boundaries of the selection was equally to the boudaries of the project is this possible?
-mads
Automatic Fill George Script
Hi madsjuul,
It's not an answer regarding your George question, but did you try the autopick color option ? Maybe it could help you to perform your filling operations.
see also : http://www.tvpaint.com/forum/viewtopic.php?t=995 I did a small video tutorial.
Just send an email to support@tvpaint.frA guess I will have to optain the SDK to get a Better George reference
