Is there a way to create rounded edges for square , polygons etc.?
I am using TVP ver 11
Please let me know
Thanks a ton
Cheers
Kunal
How to create Rounded Shapes Polygon, Square etc
Re: How to create Rounded Shapes Polygon, Square etc
Use a big round brush and outline shape tool.
Sir
Thanks Sir I am sorry I did not get it could you please explain it again?
I am trying to understand if we can create rounded shapes like a rectangle with round edges is there a way ?
In the TVP Documentation it is mentioned using grid but not sure how to get that perfect rounded edge
Here is the link https://www.tvpaint.com/doc/tvp11/index ... uides-grid
Please let me know.
Thanks again for your help
Regards
Kunal
Please let me know.
Regards
Kunal
Maybe this could help?
I would also be interested to know how the grid assists in drawing a square with round corners (unless it means using the grid as a guideline along with using the Bezier spline tool as Svengali mentions in his note above?)kunal wrote: ↑18 Jan 2020, 12:37
Svengali (and also Slowtiger) already mentioned how to do it: make a round brush with the radius of your rounded corners , then use the rectangle shape (outline , not the filled rectangle) to draw your square or rectangle. Before I saw Sven's post , I had already made a few screen shots for you, so here they are:
The documentation is misleading: there's no setting anywhere to create shapes with rounded edges.
Dear All,
Thanks a ton , this works
You all are Genius thanks again.
Cheers
Kunal
Cheers
Kunal
