Hi, I've just upgraded to TVPaint 11 Pro and while trying to load multiple audio clips have seemed to run into a problem I haven't seen discussed anywhere.
While most of my files are unaffected, SOME are being cut off before the audio is finished and there's no way to lengthen them?
My short 1 second clips are unaffected, as are my long 30 second ones. But something about 3 seconds seems to not work. They are all Mp3 files.
I've restarted my windows 10, I've reloaded the audio, I've put a copy of the audio in. I've yet to change it to WAV or edit the length of the clip so I'm gonna do that next in hopes that it won't cut it off.
Let me know if you all know anything.
Imported audio is cut off
Re: Imported audio is cut off
I've fixed the issue by converting it to .wav but I would still really like to know if there is a way to fix the issue without having to do this? It only affects certain mp3 files but not all.
