script to resize FX Stack parameters to new project size
EDIT: apparently this is not possible with George scripting (I had posted about this in Feature Requests , and Ematecki replied about the difficulties of doing something like this in George and with some suggestions of how it might be scripted in another programming language - see here .
I know almost nothing about scripting in TVPaint . So if what I'm suggesting is outlandish and quite impossible , please forgive my pipe dream.
But maybe someone who knows something about scripting can tell me if this is possible ?
I'm working on a project in 4K resolution, 4096 x 3072. I've got some multiplane scenes that are overscaled to 5K or 6K to allow for keeping the image quality sharp over the duration of long zoom-ins . Even at the "normal" 4K resolution TVPaint gets very laggy when working with the Multiplane Camera in the FX Stack.
Here is what would be useful: A script that would allow a multiplane project to be resized with the camera and planes parameters (X , Y , Z , Angle, Rotation, etc.) automatically updated to match the modified project's pixel dimensions.
For example, if I have a multiplane project at 4K 4096 x 3072 , all my planes are set up on separate layers and ready to work out the multiplane camera move , so now I would like to modify the project , downscaled to smaller pixel dimensions (say 1280 x 960) to allow for ease of use , so I can quickly position the camera and planes without the terrible lag that occurs when working at 4K.
So, at this point , my original project sized at 4096 x 3072 has been Modified to a project sized at 1280 x 960 .
In the modified project, 1280 x 960 , I will work out the multiplane camera moves.
NOW , the issue is if I try to load the Multiplane Camera Fx Stack parameters back into the full size 4096 x 3072 project , they don't work, because the parameters are for a smaller size project.
What is needed is a script that would take the multiplane camera parameters from the FX Stack in the smaller project ( in this case 1280 x 960) and automatically upscale those parameters (in this case upscaling 320% ) to work with the larger project (in this case 4096 x 3072).
Is this possible ? A script to do the calculations automatically would be so much easier than manually recalculating everything and transposing the parameters .
(EDIT: no , not possible , so I withdraw the question.)
