Need help in making script to hop between two layers
Posted: 18 Apr 2020, 12:07
by TheQuestionMark
I was wonder can anyone make a command or script where you can hop between two layers? I would like hop between the current layer and line layer. I was wondering if it can hop to any selection of within 3 of color layers if I select it but it always land back to "Line" Layer, and it goes back and forth. I have alot between layers that's in the middle of the color and line layer, it's a real hassle to tap keyboard several times. Is there such thing as script for it?
Re: Need help in making script to hop between two layers
Posted: 18 Apr 2020, 15:28
I'm just guessing: if you put all these layers in the same group, maybe the script can jump easily between these?
Posted: 19 Apr 2020, 00:24
by Svengali
This script "ToggleLineLayer.grg" can be embedded and should do what you want.
Follow these steps and
pay attention to step 5. where you must SUBSTITUTE the line name you want to toggle to...
1. create a new Action button
2. in the code box below click on SELECTALL
3. Edit the Action button to create an Ebedded George Script
4. In the "Type Script's Command" box, paste the script
5. IMPORTANT: locate and Edit the following line in the SCRIPT:
LineLayer = "name of line layer you want to toggle to"
6. Select OK to close the "Type Script's Command" box
7. Select OK to save the Action button
8. Test the button: it should toggle between your line layer and whatever other, current layer you are working on
// ToggleLineLayer.grg
// Svengali © 2020
// ( april ) 2020 - ver .0
// toggles between any current layer and linelayer
Param none
ScriptName = "ToggleLineLayer"
LineLayer = "name of line layer you want to toggle to" // put the name of the line layer here INSIDE QUOTATION MARKS
tv_LayerCurrentID
OrigLayerID = result
tv_LayerInfo OrigLayerID
parse result d d d LayerName d
IF CMP(LayerName,LineLayer) == 0
tv_WriteUserString "ToggleLineLayer" "OrigLayerID" OrigLayerID
FindLineLayer()
ELSE
tv_ReadUserString "ToggleLineLayer" "OrigLayerID"
tv_LayerSet OrigLayerID
END
FUNCTION FindLineLayer()
Counter = 0
LineLayerID = 0
LayerFlag = 1
While LayerFlag == 1
tv_LayerGetID Counter
LineLayerID = result
tv_LayerInfo LineLayerID
tv_LayerSet LineLayerID
LayerFlag = 0
END
IF CMP(LineLayerID,"none")
tv_warn LineLayer "not found... aborting"
LayerFlag = 0
END
Counter = Counter + 1
END
END
Posted: 20 Apr 2020, 03:09
by TheQuestionMark
slowtiger wrote: ↑18 Apr 2020, 15:28
I'm not sure I really need a group? I just need to hop to line layer and with the current layer, the color layer. I have 3 color layers, but I just want the color layer I'm on and want to hop back to line layer, back and forward.
Posted: 20 Apr 2020, 03:18
by TheQuestionMark
Svengali wrote: ↑19 Apr 2020, 00:24
// Svengali © 2020
Param none
tv_LayerCurrentID
FindLineLayer()
ELSE
END
Counter = 0
LineLayerID = 0
LayerFlag = 1
LayerFlag = 0
END
LayerFlag = 0
END
END
END
Thank you this is exactly what I wanted! I guess writing the code is complicated then what I imagine in my mind. Thanks!
Posted: 20 Apr 2020, 13:14
by Svengali
Happy to help.
Actually, the script is pretty simple and uses a standard method to loop through all layers to find one (or more) specific layer(s) with some characteristic like name, or status.
It also uses the config.ini file to store and retrieve data so dynamic information that changes can be passed between scripts.
