Hello ive been trying to ''correctly'' import my jason file in after effects but I can't figure out what I'm doing wrong.
When I use these setting (see image below) to import my jason file only one of the three layers show up and the composition is only 2 seconds long instead of 4 like in my tv paint file.
Settings: https://imgur.com/a/nYpq5mn
Timeline in tvpaint: https://imgur.com/a/Vrm3G1l
Timeline in After effects: https://imgur.com/RVmUQyU
I tried changing the settings while importing and exporting but nothing seems to fix the problem. This is really annoying!
Jason files not importing like in the tutorial
- Hironori Takagi
Re: Jason files not importing like in the tutorial
I usually only deal with 24fps, but I simulated your case.
I checked the script, but the reason is that the frame rate when creating a composition from layers is fixed at 24.00038.
Only the camera is a program that calculates from the frame rate set in TVPaint. I don't know why, because the developer is not in TVPaint now.
From ImportTVP5.5, I've corrected only this part. Please use at your own risk.
- 200424.zip
- (11.86 KiB) Downloaded 762 times
