Audio Pop
Yojimbo
Audio Pop
Post by Yojimbo »
On the Mac, when I load a Quicktime clip with audio, usually linear PCM, there is added a pop to the sound in TVPaint. I am not sure if it on import or when I export from TV Paint. Are there audio settings hidden somewhere I can change to get different results?
Yojimbo
The last man standing with a fist full of dollars
Patrice
Post by Patrice »
Hi Yojimbo,
All audio settings are located at the bottom of the Layer Panel.
Ex TVPaint Team
ematecki
Post by ematecki »
You mean, in the exported file ?
While playing back, it can happen that there are a few pops when the proxy is pushed to his limit and there isn't enough cpu power left for a clean audio playback.
But this shouldn't happen when exporting a file.
If you have a small example file please send it to me (the clean file without pops that will generate pops when exported).
EM.
Yojimbo
Post by Yojimbo »
Thanks. I totally missed this message. I eventually found a work around. I will see if I can't find an example where that is happening and send it to you.
Yojimbo
