Import/Export XDTS Panel
Hironori Takagi
Post by Hironori Takagi »
I received request on the following topics in the forum.
viewtopic.php?f=10&t=4161
The custom panel of "Import/Export XDTS", which has been talked about, is released here.
[20/06/17 added]
This panels reads/writes JSON data (.xdts) that transfers timeline data to Toei Digital Animation Sheet (Windows Application)
developed by Toei Animation and published by Celsys.
ExportXDTS.tvpx updated at 20/06/16 on Japanese Forum.
I set the latest 200608 edition.
ExportXDTS_200608.tvpx
(72.5 KiB) Downloaded 641 times
ImportXDTS_200415.tvpx
(73.5 KiB) Downloaded 585 times
TVPUSER
Re: Import/Export XDTS Panel
Post by TVPUSER »
Getting this functionality officially supported would be really beneficial. I use this all the time when I work with other animators who use Clip studio.
It also allows me to easily input the timing of an image sequence into after effects so I can easily work with other artists.
Even if it doesn't get officially supported I hope the script can be maintained in case newer versions of TVPaint break functionality
TVPaint 11.7.4, 12.0.2
i7-8700k, 48GB, Desktop W10
