Urgent: Help with corrupted file!
Posted: 18 Jun 2020, 11:37
Hello, everyone!
Last night I was working on a shot for my bachelor's degree animation. I saved the file and went away for a bit, leaving the software running. When I came back, the pc had shut down; I suspect it did not go into ”sleep mode” because of the latest Windows update (version 2004). When I try to load the project in, I get the spinning wheel of death and if I try to click anywhere, the program crashes. I reset the configuration, reinstalled TV Paint. The file has 91 MB, so I assume the information is still there. The shot in question is a necessary "last minute addition" to the project and it is the result of two days of work. I don't have the time to redraw everything from scratch, given that the entire film has to be finished until tomorrow.
If there is someone who could look into it, it would be much appreciated! I have attached the file below.
https://we.tl/t-8D4UQkeHe5
This is a problem that should be fixed, given that it makes the software unreliable to work with, if an OS bug or a power failure happen. Thank you!
