How to use the Philips HR2118 blender
yeneb
Post by yeneb »
The expanding blender market means that a wide range of brands and models of blenders appear on the market. However, the product that has won the hearts of housewives over the years is still the Philips HR2118 blender. So what is the Philips HR2118 blender and how to use the Philips HR2118 blender?
1. What is Philips HR2118 blender?
This is the most used modern blender in the kitchen today. The machine has many outstanding functions and how to use the Philips HR2118 blender is also very simple and easy to understand.
A. Basic features of the machine
Power: the machine works with a capacity of up to 600w to ensure the best and highest quality food processing. The machine can automatically cut off the power if it is overloaded or the temperature is too high.
Ingredients: Philips HR2118 blender contains 1 main blender and 2 auxiliary blenders. These mills each have their lids and perform different tasks.
Function: blender can be used to blend meat, blend fish, and blend fruit. There is even a very convenient ultra-fine marble blending function.
Speed: the machine is equipped with 5 buttons corresponding to 5 different fast and slow speeds depending on specific foods. In addition, the machine also has a kneading button used to mix foods in necessary cases.
B. Outstanding features of the machine
The reason for housewives to always trust this Philips hr2115 series is the outstanding features that this machine brings. Firstly, the machine has an anti-slip base. This stand helps the machine to stick to many different positions in the kitchen to ensure safety during use.
Second, the machine works according to the correct procedure. That is, only when the mill is installed, the machine will start and perform other operations. This feature helps ensure safety for families with young children or the elderly.
Third, the machine can automatically adjust the temperature. When the temperature is too high, the machine will stop working and conduct the cooling process of its equipment and machinery. With such outstanding advantages, how to use the Philips HR2118 blender?
2. How to use Philips blender HR2118
Since it is a machine that can fit almost everyone, using the Philips HR2118 blender is also quite simple.
A. Choose a mill
First, when you want to use the Philips HR2118 blender, you should choose the right blender for the food you are planning to process. The blender must ensure enough level and puree your food.
B. Install the mill into the machine
This is considered the easiest step, but you should also pay attention to some issues such as the power source, whether the position of the mill coincides with the position of the blending table, and whether the mill is sure or not to ensure the process. Blend does not crash unexpectedly. When all is checked, you choose the most suitable blending speed for each type of food.
C. Add water to the blender
In the process of blending, whatever food is, you should add a little water to dilute the food, increase the quality of the food when blending and not cause damage when the machine is operating at excess capacity.
D. Get food
When the blending process is complete, wait for the blender to stop completely, and then proceed to remove the food. When taking, you should also pay attention to avoid damage to the body.
And finally, clean the machine to be clean and dry, to ensure that the next blending is of the maximum quality. With how to use the Philips HR2118 blender as above, surely now you are no longer too confused when using the blender.
Article source and information provided by: Blending Lovers
Re: Locked but not locked
Check whether they are animation layers or image layers.
Hi Yeneb,
Could you post a screenshot of your general TVPaint winwow, please? I'm sure there is a simple explanation to this.
