Imported PNG sequence from AE loses color Topic is solved
I have a strange issue I can not solve. I hope someone can help me discover why this happens.
I am importing PNG image sequences back and forth from TVPaint to After Effects, then back to TVPaint. Some of the PNG's have color that is lost when importing the images back into TVPaint.
The attached screen captures show the problem.
The first image is from an effects animation sequence. This shows what it looks like in AE . Notice the color tint on the image (this color is actually embedded on the image , the color tint is not an effect or a blend mode in AE).
Next , I export it from AE as PNG , in RGBA mode (transparent alpha channel) . The next image shows a preview of the image. You can see that the colors are intact on the exported PNG.
(I notice that the info in the above screen capture says Color Mode: RGB , but it is in fact RGBA with transparent alpha channel).
However, when I import the PNG sequence into TVPaint the effect layer is white , the color is gone . The transparency is not lost , but the color tint is not there.
(click image to see it larger)
Can anyone tell me why this happens and what can I do to prevent it ? The same issue does not occur going the other way , exporting from TVPaint as PNG images with RGBA transparency and then importing into AE . When I export animation layers from TVPaint as PNG sequence and then import the PNG sequence into AE the color is intact . So I wonder what is happening with the image when exporting from AE to TVP ?
Re: Imported PNG sequence from AE loses color
I just guess: try different "pre-multiply alpha" settings in AE during export.
ematecki
Post by ematecki »
Does AE supports different alpha modes for PNGs ?
PNG specs say they are never premultiplied.
Try to export it with the black background, to see if this is not a colorspace issue.
I know there is no ColorSync profile, but right now I have no other idea...
ematecki wrote: 08 Aug 2020, 13:36 Does AE supports different alpha modes for PNGs ?
Here are the options for exporting PNGs from AE:
Changing these settings does not seem to make any difference.
ematecki wrote: 08 Aug 2020, 13:36 Try to export it with the black background, to see if this is not a colorspace issue.
When I exported it in RGB mode with the black background the colors are there when I bring it in to TVPaint.
My workaround now is to export the layer from AE as .MOV with Apple ProRes 4444 codec , RGBA mode. That brings the images into TVPaint as transparent image sequence , with the color intact.
However , I would prefer to use PNG sequences. It's a mystery why the PNGs come into TVPaint as totally white , with no color. When I open the same PNGs from AE in Photoshop the color is there. It also works when importing the PNG files from AE into ArtRage and into Toonboom Harmony. Only TVPaint does not import the PNG's from AE correctly.
Attached is one of the PNG images exported from AE.
ematecki
Post by ematecki »
I have no problem importing it, the colors are there.
With both TVPA 11.0.9 and 11.0.0
Mac Pro, macOS 10.12.6
ematecki wrote: 08 Aug 2020, 21:31 I have no problem importing it, the colors are there.
Interesting.
Wow ... what does that mean on my end ? What could it be ? I can import the PNGs from AE to Photoshop , ArtRage , and Toonboom Harmony with the color and transparency intact , but when the same PNGs are imported into TVPaint the color is absent . I'm on Mac OS 10.12.6 . My results in TVPaint 11.0.9 and 11.0.10 are identical -- no color in the PNGs , only pure white.
ematecki
Post by ematecki »
Is that when you drag'n'drop the file from the finder ?
ematecki wrote: 09 Aug 2020, 08:07 Is that when you drag'n'drop the file from the finder ?
Yes, but I have the same results if I import the file by File Menu > Open/Import -- the PNGs imported into TVPaint are white , no color. The original PNGs exported from After Effects have color.
The issue only happens when importing the PNG sequence into TVPaint, not in Photoshop, ArtRage, or Toonboom Harmony.
OK, you owe me an iced coffee.
Check your import settings in TVP. They're set to "alpha only", I bet.
ematecki
Post by ematecki »
I guess slowtiger hit the nail on the head...
slowtiger wrote: 09 Aug 2020, 17:28 OK, you owe me an iced coffee.
YES ! That's it ! Thank you , kind sir. (I'll buy you two iced coffees !)
ematecki wrote: 09 Aug 2020, 19:06 I guess slowtiger hit the nail on the head...
YES !
For anyone else who experiences this issue , check your import settings. Make sure the import is set to No PreMultiply.
This was so much fun. When I finally came to testing your image file, I knew it had to be on the TVP side because everything else was eliminated already. It just took a conscious look at the import panel - something I hadn't done for years! And then I danced around a bit ...
