retiming
Catriona
retiming
Post by Catriona »
I am embarrassed asking this because the solution must be staring me in the face, but how do I change a layer from 25fps to 12.5fps? ie put it on 2s?
Re: retiming
you can't change the framerate of a single layer.
Only of the project itself (Project modify)
but you can adjust the frameduration for each frame of a selection of frames. ( set exposure)
The easiest is by using the Handy custom panel.
This has a row of buttons to set the selected frames on doubles(2) for instance.
Screenshot 2020-09-21 144352.png (14.05 KiB) Viewed 4176 times
this is the best approach, leave the project at the standard video framerate and set the frameduratiopn on doubles using the handypanel.
tip: double clicking under a layer selects all frames.
