This is something so elementary, I'm sure the solution was already found.
I have a bunch of layers and want to reverse its order, that is, instead of 1 2 3 4 from top to bottom I want them to be 4 3 2 1. Is there a script for that? Or could that possibly be included in the animator's panel?
layer order reverse?
Re: layer order reverse?
Wow!
Since we're at it: how difficult would it be to add another button to the import window which would import all files in a folder, regardless of naming scheme? Right now TVP makes a guess about naming, imports everything in a sequence as long as it's not broken (1 2 3 4 all, but not 1 2 4 5, not 1 2 3 3a 4). But I very often have images with no coherent naming.
yes to this one!slowtiger wrote: ↑29 Sep 2020, 16:08 Since we're at it: how difficult would it be to add another button to the import window which would import all files in a folder, regardless of naming scheme? Right now TVP makes a guess about naming, imports everything in a sequence as long as it's not broken (1 2 3 4 all, but not 1 2 4 5, not 1 2 3 3a 4). But I very often have images with no coherent naming.
and and and...please set the project dimensions to the biggest of those images.
in case of a diverse collection of images with different proportions, TVPaint only looks at the first image and just crops off following images if the happen to be larger.
- Hironori Takagi
I have already created a custom panel to load the images in the folder.slowtiger wrote: ↑29 Sep 2020, 16:08 Wow!
- ImportFolder_200327.tvpx
- (123 KiB) Downloaded 756 times
I made a Layer Inversion panel earlier this year: viewtopic.php?f=11&t=13182
