export file names settings Topic is solved
hellofilms
Post by hellofilms »
Hi,
When you add a number in the fiename when you export a sequence TVpaint uses that number as frame number even if the number is not in the end of the filename. How can you avoid that and get a normal " scen23_A_0001" counting?
/ Mattias
Windows 11 - TVpaint Pro 11.7.4 & 12.0.2 .- Wacom cintique 24 Pro
Re: export file names settings
Just tested, I got
hellofilms
Hi,
Ok. I haven't used TVpaint for a while and used other software where the software add the number in the end so that was what I did.
Need to write out the _0001 to get it right.
Sometimes hard to work with too many software.
Thanks!
/ Mattias
