duplicate structure layer colour
hellofilms
Post by hellofilms »
when I use the duplicate layer structure it alwyas get the blue gropu color. Can you set it to duplicate the colour of the source layer?
/ Mattias
Windows 11 - TVpaint Pro 11.7.4 & 12.0.2 .- Wacom cintique 24 Pro
Re: duplicate structure layer colour
Good idea, I'll add it to the list.
hellofilms
Fine. Would be great.
Then I know you can make that setting now.
/ Mattias
hellofilms wrote: 07 Oct 2020, 09:15 when I use the duplicate layer structure it alwyas get the blue gropu color. Can you set it to duplicate the colour of the source layer?
/ Mattias
what do you use to do that?
i have re-used the button from the old animator panel called: Duplicate the current layer and clear heads.
it keeps the original layer groupcolorcode...
hellofilms
Yes I used to do that before. But now I cant find that. Is it gone.
If it's not much work Peter, it would be great if you send upload it here.
Thanks!
/ Mattias
animatorpanel.tvpx
(1.82 MiB) Downloaded 740 times
thats why i put up the image, you can rebuild it in custom panels its only 2 standard commands.
hellofilms
Thanks, for the file, Peter!
I have been away from TVpaint for a while so I realize that I had forgotten many things, but they keep coming back quite fast luckily.
hellofilms
Peter Wassink wrote: 07 Oct 2020, 18:15 animatorpanel.tvpx
Now the layer come below the source layer. Is is possible to set it to duplicate above instead?
And can you set a prefix to the name as well?
/ Mattias
