Hi, I am able to assign a keyboard shortcut to a quicklook command from a custom panel, the problem is, it doesn't work. When I press it on the panel, it works, always. But for some strange reason, if I use a keyboard shortcut I assign, it works once, then it stops, makes everything disappear from the view, including the black line.
Why is that and how to fix it, please?
It is pointless function if I can't assign it to the keyboard shortcut, IMHO.
quicklook bug report
TV Paint 11.5.3 Windows 10
Re: quicklook bug report
ok, I understand why maybe it is happening, and it can be avoided if I press the shortcut when my cursor is not above the view window. So maybe that is creating some collision in interpretation of the interaction.
Update - this is definitely the user interface bug and I hope it will be resolved in future versions. It is unrelated to where my cursor is, it just stops working. When I press the button on the custom panel, it works, when I press assigned keyboard shortcut, it doesn't.
Okay, thanks for your report, could you please describe the steps to reproduce so that I can see if it's a bug ?
