Cannot eliminate blue lines
Posted: 28 Oct 2020, 00:11
by Milton Gray
Hello. I very recently purchased TV Paint 11 Pro. My iMac computer is OS 10.15.6 Catalina with 32GB of memory, one terabyte of SSD storage, and 4K resolution. My Wacom Cintiq Pro 24 has 4K resolution. My Cintiq and my iMac are completely new and dedicated solely to my TV Paint 11 Pro. Recently I have been trying to do something very simple, without success: I have been following the video tutorial by Aaron Blaise called "More Recent Features" (listed at the top of page 3 of tutorials on TV Paint's website). In this tutorial Aaron begins on the TV Paint screen with a blank white page to draw on, and goes to the vertical drawer on the right side of the screen, to the RGB Sketch Panel. There he clicks on the blue pen, then he goes to the vertical drawer on the left side of the screen to click onto "Pencil". Now he begins drawing blue lines on the screen. Shortly after, Aaron returns to the vertical drawer on the right side of the screen, and in the RGB Sketch Panel he clicks on the blue "X" to eliminate the blue lines. But when I do that, the blue lines I drew with the "Pen" disappear, while the blue lines I drew with the "Pencil" do not disappear, and instead they change to black. I have tried this several times, including completely shutting down both my TV Paint 11 Pro program and my iMac computer, waiting a few minutes, then rebooting both again, to be sure that there wouldn't be some earlier glitch somewhere that might be the cause. But my results are always the same: the blue "Pen" lines disappear while the blue "Pencil" lines just turn black and remain. Is there something I should do differently, or perhaps should the TV Paint 11 Pro software program be re-installed to eliminate an odd glitch?
Re: Cannot eliminate blue lines
Posted: 28 Oct 2020, 10:36
The blue eraser X in the Sketch panel only deletes one very certain hue of blue, the one of the blue pencil in the same panel. If you use any other brush tool with that exact blue, the lines will be erased as well. If you use a different blue, anything darker will remain gray after using the blue eraser.
Posted: 28 Oct 2020, 13:03
by Peter Wassink
Actually you can make any tool work with the sketchpanel functionality, be aware of these two limitations.
1) use the AA part of the Sketchpanel
- AA-sketchpanel.png (11.41 KiB) Viewed 6286 times
2)make sure to use the exact same single colors (basicly the 3 100% R,G and B colors) the tool should not create variations in RGB value
Posted: 29 Oct 2020, 21:14
by Milton Gray
Peter Wassink wrote: ↑28 Oct 2020, 13:03
Thanks for your reply. I did what you suggested, although maybe I should ask, what is the "AA part of the Sketchpanel"? I was drawing on a fresh page on the Sketch panel, just as shown in Aaron Blaise's video tutorial that I mentioned in my first question.
Posted: 30 Oct 2020, 12:53
Milton Gray wrote: ↑29 Oct 2020, 21:14
AA" referring to
Sketch Panel RGB with Anti-Aliasing , not the Pastel Without Anti-Aliasing or Pure Without Anti-Aliasing .
- SketchPanel_RGB_with_Anti-Aliasing.jpg (71.9 KiB) Viewed 6222 times
