[Pro] Switch between configurations
Xavier
Post by Xavier »
Did you know that you can easily switch between configurations ?
https://www.tvpaint.com/doc/tvp11/index ... nces-start
Re: [Pro] Switch between configurations
Did not know that one. Possibly, could be quite useful! Going to experiment with that, thanks.
One question: does each new configuration require equivalent amount of storage space?
sven
EDIT: Already, I found one thing to note: The TVPaint Documentation says...
By default, the configurations are located in the folder :
- for Windows users :
C:\\Documents and Settings\\your_name\\Application Data\\TVPaint Animation 11 (pro)
For me, I find the configurations in a different place... in the following folder:
- for Window users :
C:\Users\yourname\AppData\Roaming\tvp animation 11 pro
includes a folder for each configuration plus the system.ini
Xavier
Post by Xavier »
Svengali wrote: 29 Oct 2020, 20:57 - for Windows users :
[/color]
I think that this part of the doc was written for a really old version of Windows :)
Yes, I can confirm that the location on Windows 7 and Windows 10 is C:\Users\yourname\AppData\Roaming\
I'll change this as soon as I can :)
