What does this error message mean?
I received an error message that I've never encountered before. The message said:
panic:Cache File bad size (4096-0117572351)
Panic-Cache File bad size 40960117572351.jpg (8.52 KiB) Viewed 4462 times
I received this message when I was trying to load a .mov file , 9MB in size , 1280 x 720. So not a huge file , but after the error message popped up TVPaint was frozen
and I had to force quit.
What does this error message about "panic:Cache File bad size" mean ?
Re: What does this error message mean?
Xavier
Post by Xavier »
Apparently, it's an I/O error on read. The size of the cache file is different than what is reported. Is your filesystem ok ? it can happen when a filesystem is corrupted.
Does it happen each time you import the file ?
