Config samples
Xavier
Config samples
Post by Xavier »
If your config crashes TVPaint, I'd be interested to have a look !
So please zip it and send it to me :) (but only if it crashes TVPaint !)
Note : it will remain private, used for testing purposes and nothing else.
Hironori Takagi
Re: Config samples
Post by Hironori Takagi »
I ran into a config file corruption just the day before yesterday.
I was recreated the setting folder. I attach the troubled setting folder.
Xavier
Re: Config samples
Post by Xavier »
Sorry, I think you forgot to attach the file
Hironori Takagi
Re: Config samples
I'm sorry. I didn't notice that it exceeded the attachment limit of 30MB.
The following will be available until around November 20th.
https://drive.google.com/drive/folders/ ... sp=sharing
Xavier
Re: Config samples
Post by Xavier »
Thanks ! I got it, and I could reproduce the crash.
Hironori Takagi
Re: Config samples
I relieve that you confirmed.
The data will be erased soon.
Xavier
Re: Config samples
Post by Xavier »
Xavier wrote: 09 Nov 2020, 17:20 If your config crashes TVPaint, I'd be interested to have a look !
Guys, I'm still looking for config samples :) the purpose is to stop TVPaint crashing when it doesn't like the config !
Sewie
Re: Config samples
Post by Sewie »
Hi Xavier,
When I updated to 11.5 TVPaint wouldn't start because it said that it couldn't find the dongle (it was plugged in and I tried everything) . Does that count as a crash as well?
I have since gone back to the previous version of TVPaint because I couldn't afford to spend too much time rearranging my configuration.
Xavier
Re: Config samples
Post by Xavier »
Sewie wrote: 24 Dec 2020, 14:30 Hi Xavier,
Hi Sewie, no I'm afraid it doesn't count. Have you tried just to start with a fresh new config to see if it works ?
Or you can enable the startup panel to choose your config folder at startup. Go to Edit>Preferences>Startup (tab)>Startup configuration, choose "Open Startup Panel" from the dropdown menu and restart TVPaint.
