AA coloring issues
AA coloring issues
Precise coloring with Anti-Alias can be problematic
with the paintbucket set to anti alias we get a 'balooning'effect on the fill
this also happens when exporting the C&T layer set to anti-alias
This Anti-Aliasing effect seems to me to be a bug, or a symptom of some non optimized algorythm.
It was reported earlier i believe, cant relocate that but ran into this issue again.
The fill tool with AA or the Col&Texture layer set to extract with AA, both give the same distortion of the filled shape,
making it look as if its blown up.
i would think that a perfect square should look the same with or without AA,
only when a line has an angle other then 0° 90° 270° or 360° should AA kick in?
to me it seems weird that the AA would cause a square to blow up like a balloon even growing outside of its fill boundaries.
Another thing i noticed with is that the fill border goes up to the border on top and Left of the fill.
But it goes over 1 pixel to right and bottom boundary?
Why is the fill asymmetrical?
You can see it in this image, where i put the layer with black boundaries at 30% opacity
Xavier
Re: AA coloring issues
Post by Xavier »
Yes, i think you reported it in the beta thread. Thanks anyway, it's better here :)
yes we are currently struggling with this issue.
And when i revisited my post, i saw you suggested i put it here.
i mean this a-symmetrical filling.
we use the C&T and these edges cause us problems in compositing.
colo&texture-AA-issue2 .png (12.49 KiB) Viewed 17961 times
Xavier
Post by Xavier »
The multiply blending mode is a pain to do. I also have an aliasing issue...
Xavier wrote: 25 Nov 2020, 09:39 The multiply blending mode is a pain to do. I also have an aliasing issue...
Yes i imagine Aliasing is hard to get right
i'm not sure what multiply has to do with this issue specificly, could you elaborate?
Xavier
Post by Xavier »
Peter Wassink wrote: 25 Nov 2020, 09:49 i'm not sure what multiply has to do with this issue specificly, could you elaborate?
Completely unrelated, just to let you know on which topic I am currently :)
Xavier
Post by Xavier »
Peter Wassink wrote: 25 Nov 2020, 09:36 yes we are currently struggling with this issue.
Thanks for the detail level, no worries I'll have a look.
artfx
Post by artfx »
I wonder if this is why I notice in videos about Japanese studios (that use TVPaint) that they use no antialiasing, on their lines or colors... none... nowhere.
Back in the day when we had a 2D team at the studio in Shanghai, I don't know what software they were using for ink and paint, but I was surprised to see the same thing. No antialiasing on anything.
I wonder what resolution they must work at to make that look good.
Terrence Walker
MacOS Monterey Version 12.6.2
Hironori Takagi
Post by Hironori Takagi »
artfx wrote: 21 Dec 2020, 22:19 I wonder if this is why I notice in videos about Japanese studios (that use TVPaint) that they use no antialiasing, on their lines or colors... none... nowhere.
There are two reasons why we don't color with antialiasing.
(1) It takes time to color.
(2) When compositing, use the color area as mask.
After adding textures and effects with each color area, antialiasing is handled with plug-in effects.
artfx
Post by artfx »
Hironori Takagi wrote: 24 Dec 2020, 09:37
Wow! Thanks for answering and explaining that. I didn't know that antialiasing could be added later. This is very good information.
Terrence Walker
Hironori Takagi wrote: 24 Dec 2020, 09:37 There are two reasons why we don't color with antialiasing.
Are the plug-ins to add antialiasing to the image plug-ins for TVPaint or in another application ?
Hironori Takagi
D.T. Nethery wrote: 28 Dec 2020, 20:31
For example, we use After Effects plug-in "OLM Smoother".
https://olm.co.jp/rd/technology/tools/?lang=en
Hironori Takagi wrote: 29 Dec 2020, 10:37
Thank you. I've downloaded it and will try it.
Do you apply the OLM Smoother to a single composite layer (characters and backgrounds) in After Effects or is OLM Smoother applied to
separate layers of characters and backgrounds in AE before doing the final export to .MOV or .MP4 from Adobe Media Encoder ?
