Applying Transform Tool On Just One Frame
le_femto
Post by le_femto »
Hello!
I am trying to match the dimensions of my frames by using the transform tool. When I make an adjustment on one frame, it affects every frame in the sequence. I would like to only apply a transformation on one frame.
I'm sure this is an easy solution, but for the sake of following the forum instructions, I am using TVPaint 11.5, 64 bit, Windows 10.
Re: Applying Transform Tool On Just One Frame
The transform tool will only apply on the selected frame(s).
If all frames are transformed, this must mean you have selected all frames before you applied the tool.
le_femto
Post by le_femto »
Thank you, Peter. My error was in presuming that because the transform adjustments (pre-application) were being represented on every frame, it would apply to all. Once I applied a transformation to one frame, it was evident that that was the only frame affected. Your feedback was helpful :)
