instance/exposure paste to selection in11.5
ini
Post by ini »
I think this is also different from previous version,
and it seems side-effects of the fuction-delete-fill gap
when we copy instance/exposure
and select other instance/exposure and paste copied, the current selected is replaced by copied.
It's same but it moves to right,
as much as replaced amount of instance/exposure.
in 11.5
https://imgur.com/MtmnjLj
previous
https://imgur.com/X3KXDJ5
Re: instance/exposure paste to selection in11.5
i don't understand your post,
Its not clear to me what you are doing and i can't replicate.
i do love how you now can drag and drop frames between layers and
would like to see this added to the copy paste move options between layers:
move + insert.png (26.99 KiB) Viewed 7993 times
ini
Post by ini »
well.... It's not in between same layer,
1.select image you want to copy, and copy selection(crtl+c)
2.select images you want to be replaced, and paste (crtl+v)
then, that images will replaced with copied images
previous version replaced it without changing the starting frame,
but 11.5 version is changing it just amount of replaced(deleted images)
I think it's because deleting images is now defaultly delete images with filling gap from left.
ini wrote: 30 Nov 2020, 16:34 ...
yes, i see what you mean now.
to me that's a bug
Xavier
Post by Xavier »
ini wrote: 30 Nov 2020, 16:34 I think it's because deleting images is now defaultly delete images with filling gap from left.
Yes indeed that was the reason, nice intuition ! thanks for the report, the release will be updated soon.
ini
Post by ini »
nice, thank you!
Xavier
Post by Xavier »
you're welcome ! is everything okay now ? sorry about the bugs
