remove exposure in Xsheet
ini
Post by ini »
I'm using X-sheet currently,
and I found some is unsable in x-sheet layer.....
those fuction is usable in Xsheet layer,
-add exposure
-clip: delete image
-clip: add single image
-Layer : set Frame repeat
but we can not use
-Layer: Exposure : remove single
-Layer: Exposure : remove all
in Xsheet layer.
is it possible to use those in Xsheet layer too, someday?
Re: remove exposure in Xsheet
I thought xsheet layers were made redundant? What version are you working?
Peter Wassink wrote: 30 Nov 2020, 17:06 I thought xsheet layers were made redundant? What version are you working?
X-Sheet is still there , but is hidden by default. You have to enable it in the Preferences, under Display > Display X-Sheet Tab.
ini
Post by ini »
yes, It's still there......
Peter Wassink wrote: 30 Nov 2020, 17:06 What version are you working?
I'm using 11.5
