eraser does not work properly
Posted: 03 Dec 2020, 18:04
by bouwine
Hi there,
I was wondering if someone knows the answer to a technical issue Iām having.
Yesterday I bought the newest Tvpaint pro 11 and started working with it today.
When I am drawing and use the eraser by clicking the button on my pen, it will erase with a big dot at first. It is only after a second or so that the pressure sensitivity will start working. When I stop erasing it will erase a big dot again. I have attached an example of what I mean. It makes it hard to erase precisely. I am using a custom made brush which I have used in a previous Tvpaint version without a problem. I also noticed that it happens with the standard brushes in the program itself.
This is what I work with:
Macbook Pro, Mac OS Big Sur, version 11.0.1
Wacom 22 HD, driver version: 6.3.41-2
Bouwine
- example of how the brush erases with a dot at the beginning and end of a stroke.
- Screenshot 2020-12-03 at 16.44.23.png (97.5 KiB) Viewed 9465 times
Re: eraser does not work properly
Posted: 04 Dec 2020, 00:09
by Xavier
In the eraser options, try untiking the preview checkbox
Posted: 04 Dec 2020, 17:49
by bouwine
I have tried your suggestion, but unfortunately it does not solve the problem. Could. the problem be, because my computer works with a new chip?
Posted: 05 Dec 2020, 00:28
by Xavier
No, I don't think so, it's possibly a bug. I'll check that on monday !
BUT : could it be somehow related to the pressure sensitivity of your Wacom tablet ?
Posted: 05 Dec 2020, 01:03
by Xavier
bouwine wrote: ā04 Dec 2020, 17:49
Thinking about this, yes it could actually have an impact.
Did Wacom release a driver for Big Sure ?
Otherwise, the driver you installed works through an "converter" that translates the instructions, to make them understandable by your Macbook processor. It mays explain the wrong pressure value that is received by TVPaint.
Posted: 07 Dec 2020, 13:04
by bouwine
Hi Xavier,
My Cintiq has the latest update which is also made for Big Sur. I have made some screenshots.
Perhaps it is a bug in Tv paint after all? If you need more information about my computer please, let me know.
Bouwine
Posted: 07 Dec 2020, 15:51
by Xavier
It may be a bug in TVPaint. But since you use Big Sure, it may also be a compatibility bug elsewhere.
I sent you a like to the demo version of the previous version (TVPaint 11.0.10) by PM, please tell me if it behaves the same.
Posted: 08 Dec 2020, 18:05
by Xavier
Try with the update, just in case :
viewtopic.php?f=10&t=13927
Have you tried starting with a fresh config folder ?
- Close TVPaint
- Go to Library, move all the "tvp animation" folders into a new archive folder (say "tvp config archives").
- Start TVPaint
Posted: 10 Dec 2020, 12:42
by Xavier
I'm currently trying to reproduce this, without success so far. Given the screenshot you attached, can I assume that you configured your pen to have F4 on the side button ?
If so, it's rather the drawing mode of your current brush that you change to erase, rather than the eraser (the separate brush).
Have you tried resetting your Wacom settings ?
