The filled stroke tool is broken 11.5 on sierra Topic is solved
Animationriver
Post by Animationriver »
Hello!
The filled stroke tool is broken. I cannot return the color mode.
Mac OS Sierra
Mac Book 15
+VIDEO
https://cloud.mail.ru/public/pB2w/4khwz2kCF
test.mp4
(4.93 MiB) Downloaded 856 times
Снимок экрана 2020-12-04 в 13.03.46.jpg (31.68 KiB) Viewed 13424 times
Re: The filled stroke tool is broken 11.5 on sierra
Hello, does pressing the F# keys change anything?
Xavier
Post by Xavier »
Did you check your stylus (driver) settings ?
It's most probably related to this : viewtopic.php?f=10&t=13813&p=121631&hilit=flip#p121631
Animationriver wrote: 04 Dec 2020, 11:57 Hello!
Mac OS Sierra
Mac Book 15
+VIDEO
I am also on Mac OS Sierra , Macbook Pro 15-inch , late 2013, running TVPaint 11.5 . I watched the video you posted and I tried to reproduce the same issue you show in the video , but the Filled Rectangle , Filled Stroke tools are working normally for me. I can not reproduce the same issue you are showing in the video.
Xavier
Post by Xavier »
Uffff it's a relief :wink:
Animationriver
D.T. Nethery wrote: 04 Dec 2020, 16:38
Mac OS Sierra
Mac Book 15
+VIDEO
1.
This problem does not occur immediately. It appears after some time of use.
Intuos pro 2019.
2.
I haven't updated the driver from wacom. Because I was afraid of the return of problems with the line, which arose after version 6.3.37-2 on CINTIQ 27 QHD.
3.
I do not know what the problem is. But isn't that worthy of attention? I didn't think about updating the driver. Rather, I will return to the TVP version 11.08
Xavier
Post by Xavier »
On monday I'll make optional the automatic eraser mode when you flip the pen (and disabled by default). Hopefully it will solve your issue.
The thing is that you can have various hardware (tablets) and various parameters to use then pen, depending on your hardware. So I assume that handling the pen flip causes more side effects than benefits. Sorry about that.
However, it's still weird that it happens only with the filled strokes.
Animationriver
Xavier wrote: 05 Dec 2020, 00:43 On monday I'll make optional the automatic eraser mode when you flip the pen (and disabled by default). Hopefully it will solve your issue.
1.I turned on two versions of the program at the same time 11.08 and 11.5.
2. I have disabled the eraser on the other side of the stylus.
3. In version 11.08 everything works as it should.
In version 11.5, the eraser mode is enabled.
And it cannot be returned back to color or other mode.
4.Restart program. all work good////2 min --- problem
:roll:
Xavier
Post by Xavier »
Animationriver
Xavier wrote: 08 Dec 2020, 18:04 get the update ! viewtopic.php?f=10&t=13927
Thank you very much! You are the genius of your work! Everything works comfortably!
:D :D :D :D :D
Xavier
Post by Xavier »
Thanks for your feedbavk ! Enjoy :)
